Hi there. I need to make detailed construction stair drawing, concrete stairs with metal railings.. any one has any example? so that i can check it out. So far i planned to show staircase with all levels plans, 2 sections and some details. Should I make separate drawing for railings? Tips please ;>
Any stair drawing example?
Depends on what the real purpose is? Are you creating a real set of construction drawings which the manufacturer will use straight in the shop? or are you "just" showing the design intent to the manufacturer, who´ll then be creating the actual construction drawings?Klaus Munkholm
Originally posted by bangobeat View PostTips please ;>
Seriously though dude, you need to look at your office's output, and seek guidance/education from your seniors on matters like this - if for the sole reason we all have different documentation conventions and standards.
Only tips I would suggest:
1. Do the all of the stairs as single - not multi-story. If you have to make changes, it's a bit tricky.
2. Do all of the stairs first, then do the railings.
3. In a concrete/monolithic stair Revit creates what looks like an extra riser line at the top of the stair. This is not a riser, it is the end of the stair.
4. If you have a custom stair arrow for plans, you have to make the arrow as a detail component and draw it every view and turn off the Revit stair arrow per view, because you can't make custom stair arrows.
5. Make a stair tag for number of risers – That is something office specific for us.
Other than that, I agree with snowyweston - check with someone in your office for standards.
If I think of anything else, I'll chime back in.
Hi all,
Is there a way to create concrete stairs that are flush with the ground? It's for a pool, but Revit's native way to make stairs gives the...October 9, 2015, 03:47 PM -
I have a precast concrete stair that I can create top landing notch but not sure how we can do bottom landing notch. Can revit 2017 have an option to...December 19, 2017, 02:25 PM
Firstly, a few general matters.
Given the change in the stairs with stairs by components etc, one needs to use the new templates which...March 27, 2012, 10:09 PM -
I have been tasked with redesigning my bosses new house. The house itself is really rather large and he intends to make it larger still by reusing spaces...March 5, 2015, 12:05 PM
I am trying to create a concrete stair with a landing that is out of square
The stair is cast insitu and revit will not let me create it...November 18, 2020, 08:49 AM
Monumetric Footer In-screen
