Section Views Not Showing
This topic is closed.
    Someone refresh my memory on this...
    I have a basement plan and in that plan there is a section cutting through the stairs. I have another level about 2' up from the basement plan that is identical to the basement plan but the section through the stairs is not showing up. The section is the entire height of the building... any reason why its not showing up on this new level?
    It's not hidden and it doesn't show even when the crop region is turned off.
    Chad Koscinski | Architect
    Is the new level set to a scale that is smaller than the 'Hide at scales coarser than' parameter for the section?
      Bingo! That's exactly it. I had just run into that same problem before Thanksgiving and totally forgot the answer since then... nice to have it the archive now so I can search for it when I forget again
