move to next level up?
    Hello all,
    I s there a way to move to the next level up without having to go to the project browser?
    Thanks,
    Hi qutaibah and welcome to the forum,
    The only way I know of changing levels other than via the browser list is to double click on a level marker in an elevation or section.
    William Sutherland rias riba
    WS Architecture Ltd
      ... or right click and select "Go to Floor Plan". Works with sections, elevations etc as well.
      [email protected]
      http://4revit.com
        never knew that one, thanks
        WS Architecture Ltd
          You could have multiple floor plan views open and tile them and click from one window to the next to change levels.
          Jeff Hanson
          Sr. Subject Matter Expert
            Thank you for your input folks,
            It would be helpful if there was a command (with it own keyboard shortcut) to make the transition between levels easier.
            Thanks again for you help,
            Qutaibah
