Callout w/ text parameter
    It seems so simple but its giving me fits..... I want to have a callout (be it a section, detail cut, etc.) with a text parameter much how you can in a detail item tag. So if i write something in the type comments it appears next to the callout bubble. I tried to use the Ref. label but then my note appears every time I ref. that detail.
    Regards,
    Emmett Cruey
    ConnectedBIM.Design
    925-695-6000
    Not possible with Revit callouts.
    If it's critical you can try using a View Reference instead of a Callout/Section/etc. You'll need to have multiple types for varying sizes of the callout bubble/section line/etc., and it won't be live to the model, but it will let you do what you want about as intelligently as possible.
    Greg McDowell Jr
    about.me/GMcDowellJr
