Can't open project file
    this is a new one on me. Any idea of what this means. What it means to me is that I can't open XP!S-A-0-000-DM.rvt ??
    Have you tried opening with an Audit?
    If audit doesn't work I believe that is a corrupt file to be sent to Autodesk...
      I think this means you may have an insufficient memory problem? Saw this back in Windows XP 32 bit days when files got too large.
      How big is the file? How much RAM on the machine?
      Cliff B. Collins
      Registered Architect
      Autodesk Expert Elite
        ummm... look at his sig...
        Will be a tutor someday...
        Revit Arch 2011 Win 7 Pro 64 bit
        Intel I7-860 @2.8GHz
        12GB DDR3 RAM GeForce GTX260
        -Alex Cunningham
          203MB and 12GB
            yep, Audit no worky
              Have you tried restarting Revit?
              -Alex Cunningham
                "Past it's end" errors typically mean the file is toast. You can try sending it to support and there is a chance they can recover it, but I would start looking at a back up just in case.
                Jeff Hanson
                Sr. Subject Matter Expert
                  thanks, fortunately the file is an Architectural model received on a CD today for a new project that I'm starting. I'll just request a new file...
                    So then "past it's end" is Autodesk's way of saying the file has "passed on"?
