Date on Title Block
    Date on Title Block
    Hi everyone
    I would like to add date stamp alone on my title block without time stamp is there any way in which i can avoid the time stamp being displayed??
    I can only add both i don
    Refer the attached image
    I would also like to do this and get away completely from manually filled in drawing dates, but I think the only way would be a macro that writes the current date to a 'Current Date' shared parameter in the title block when the project is opened.
    Unless you can cover the time with a masking region or something.
    Although I quite like it when other team members/managers can see that you where still working at 03:14 the night before
      See this. Total hack though.
