I'm brand new to Revit, sorry if this is elementary - but - how do I trim a foundation wall to a topo surface in an elevation view - the view shows the wall above & below grade. Associated question, - having turned the visibility of the foundation walls OFF in this view by element, how do I get them back?
thanks! Will
To "trim" the wall in an elevation view, simply click on the wall and grab the top grip and slide it down. Or, if you know what elevetion the top of wall should be at, you can manually enter it in the properties window.
As for turning on individual elements, click the REVEAL HIDDEN ELEMENTS button (the light bulb) and the drawing area will have a pink boundary. Select the items you want to unhide and right-click and select the appropriate option from the popup menu.
I am trying to do the same thing but I have a complex topo and I wish to trim the wall to the topo and attach.
Basically, the site is in Churchill, Manitoba Canada, (read tundra) and I am trying to model a heavy stone masonry structure anchored directly into the exposed granite. I have the topo created as well as the walls but the walls are currently just floating in space, going through the topo and they need to be attached.
I have included the Revit file (I have RCAD 2011) as well as two photos from the site to help you understand.
Unfortunately, there is no way to attach the walls to the topo surface.
Ok, well, it could be done with some amount of API programming. This would not attach the wall, but one could trim the wall profile to the topo surface.
I have a good topo of my site & need to show site elements, retaining walls among others. I can think of a few ways (not actually walls though) given...
Is there a way to only have the lines created from a sub-region on a topo, rather than a surface?
thank you,
June 15, 2017, 05:00 AM
We process personal data about users of our site, through the use of cookies and other technologies, to deliver our services, personalize advertising, and to analyze site activity. We may share certain information about our users with our advertising and analytics partners. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
