Render error. Help?
    Render error. Help?
    I came back to do a final rendering and now I am getting this message. I have no idea what these files are. If I could at least be told what they are, then I could remove them and then render.
    Thanks
    You can still render with them missing, just hit ok. They are images used for a material, or it's bump, cutout, transparency etc. The image either changed location, or might have been brought in with a family. Sometimes the object is hidden in view and it doesn't affect a rendering, otherwise it will render as white/default material. Test renderings help identify them.
    I have found if I select the paint tool and scroll through the list materials that have a missing property will have a warning exclamation sign. I don't see this in the regular material browser for some reason.
    Julie Kidder
    Architect + BIM Director
