Urgent help.. Revit bug or smth..
    When i select smth, instantly revit bounces screen up and down and everything that i select moves because i just click on it. Impossible to work. Tried to restart revit etc.. nothing.. Something wrong with my revit..Help? do i need to make video? or maybe you wanna see my shared skype screen please?
    What´s smth ?
      smth == something
      remove the uistate.dat file. This should help at least for a while
      [email protected]
      http://4revit.com
        It's youngspeak for Something.
        Don't cry, don't raise your eye, it's only Revit wasteland.
          Sounds familiar. I used to have that problem in RAC 2011 when the quickacces toolbar was below the ribbon. When switched back to above the ribbon everything worked fine.
          Arjan Ikink, BIM-engineer at PHB Deventer
          LinkedIn
            Changed some things, like some bars and visual options , restarted revit and now its ok.
              Ahhh... Typical youngsters! They are too lazy to pull up their pants, so it´s no surprise that they are also too lazy to type all the letters in a long word like "something"
                Well many short words I didnt and sometimes i dont understand what "not youngsters" writes: such as OP, IMHO. Even some words like Generic profile u might write GP . Other words like POTM also not understandable for newbies .. etc ( Et Cetera)
                  I had this problem suddenly appear a few months ago. Found the answer to be here post #4 and more here. Redocking the project browser and existing Revit worked for me, hopefully you too.
                  D
                    Uncheck "Click+Drag". It won't fix the bouncing, but your stuff won't move.
