section lines ?
    section lines ?
    Hi guys. I have a question hope you can help me. I am new to revit and want to draw an angled section line ( for ex: on plan view it must be like a broken line with 45 degrees.) (__/) something like this line =) the problem is it gives two sections not one.
    Thank you for your time.
    That would be 2 sections, you won't to my knowledge get revit to do that in 1 section. You could take the 2 sections and put them together on the same sheet to achieve your desired result.
    Rob Pivovarnick, AIA
    Senior Project Architect
    Michael Graves Architecture and Design
    LinkedIn Profile | @ Twitter
      Could you upload a picture of what you are trying for? You can draw angled sections but you can only split them parallel to the original line. If you want the section to change angles you will need to do multiple sections.
      Julie Kidder
      Architect + BIM Director
