how to control the overlaping elements....
    Hi dude!
    i have problem in revit like overlaping object like wall&columns, I put columns in floor plan but doesnt show the columns on the plan,.
    its any setting changes is there.
    You get 2 sorts of columns, make sure you're using the correct one for the purpose you want.
    Architectural columns - see these as dummy columns and wall piers. If they touch a wall the wall extends into them. If they're inside wall they disappear.
    Structural columns - see these as "true" columns. If they touch a wall, the wall is cut around the column.
