Revit Scheduling - from Excel to Revit
    I have a basic question - How do you guys import data from Excel to Revit? i have been doing this using "Copy Spreadsheet" third-party software, but it is so sensitive when operating....Has anyone used something more up-to-date and more reliable?
    Thank you, PHXARCH
    We're currently using QuickTable from Tools4Revit.com. Not the best solution, but it's about our only solution right now.
    Leanne Zaras, CDT, LEED AP
      http://www.dotsoft.com/revit/xl2revit.htm
      This might be an acceptable solution to you as well.
        ...thank you for your input!...Much appreciated....
          phxarch, for big volumes of data, RDBlink is the tool.
          For a single schedule I stay with Nicolas or Medina copyspreadsheet script.
          And it is reliable, you just have to play by the rules and avoid sorting issues.
          Gonçalo Feio
            My firm's been contacted by resellers for Ideate BIMlink. Haven't had a chance to use or review it myself yet, not a feature I expect to use too often. May be worth a look.
            http://www.ideatebimlink.com/
              From my understanding (and correct me if I am wrong Ideate) BIMLink is a push pull addin. Meaning it allows you to pull a schedule from within Revit, export to Excel, make changes in Excel, then push those modifications back into Revit.
              -Alex Cunningham
                The Revit Extensions for Autodesk Revit Architecture 2012 contains the Excel Based Model Generation add-in. From the 5 minutes hands-on I've had it allows you to generate a basic model containing levels, columns, beams, walls and footings. Not quite a complet model, but it's a start.
                Arjan Ikink, BIM-engineer at PHB Deventer
                LinkedIn
                  which doesn't work with Win 7 64 bit making it useless for most people...
                    What's 64bit???
                    Seriously, why on earth are they still publishing tools that only work on 32 bit. The official point of view has been "use 64bit systems" for quite a few years now!
                    • Revit and excel
                      Is it possible to to enter data into excel to generate a revit model from the data in excel?
                      June 25, 2013, 02:50 PM
                    • Selecting Excel Cells into Dynamo to Revit
                      Hi All, learning a little dynamo at the moment, playing with excel. Read a number of posts on here to get some great ideas, but I am having trouble, sort...
                      March 30, 2016, 12:32 AM
                    • Excel VBA
                      I am trying to create a complex excel workbook for my second job and need some help with VBA for excel. I was hoping that someone on here as this experience...
                      October 30, 2015, 12:49 PM
                    • Any Excel gurus here?
                      I know, seriously OUT THERE right?
                      Anyway, I am trying to figure out why a particular font is working in MS Word, but not Excel. It isn't even...
                      December 10, 2012, 02:57 AM
                    • David Light: Exceler8
                      In the early days of Revit it was not easy to export data from Revit to Excel, but it was possible. Then suddenly it got difficult for the average...
                      July 2, 2013, 05:45 PM
