Revit 2012 Installation Error
    Hey guys,
    I was helping a friend install Revit Arch 2012 and encountered this error. (see attached)
    Does anyone know how to fix this?
    OS; Windows Vista 64 bit (through bootcamp)
    Thanks in advance for any help!
    Juan Carlos Moreno
    Sisley Cosmetics
    Did you get this fixed Juan ?
      Not sure but seems like a visual c++ instillation error. Possibly try and remove all versions of visual c++ and then do a disc cleanup and reg clean up. Then do the re-instillation from Revit discs.
        Yes, Sorry for the delayed response but the issue was a visual C++ error as mentioned by Elmo, I found a link on the Autodesk discussion website Here
        I clicked on the first link, ran the tool to fix the issue, rebooted the computer and finally was able to get the installation to work.
        I hope this helps someone with a similar issue
        Juan Carlos Moreno
        Sisley Cosmetics
          Great to hear. Seems like c++ errors are not going to going away for a while.
