Corner Panel Model In Place
    How would you model this?
    -Alex Cunningham
    What do you mean? Looks like you already modeled it... so what´s the problem?
      Is there a better way? I would like it to be parametric.
      -Alex Cunningham
        Hate that.
        It's just like corner windows.
        No straight workflow.
        Just trick and I hate those.
        Gonçalo Feio
          Then don´t do it as an in-place. Create a loadable family instead... parametric´s won´t be an issue then.
            I'd go with a Generic Model. You can make those parametric. And save and reuse
              The in place was started by someone else, and due to time constraints I didn't rebuild it. :-\.... basically..... Just questioning myself on if I could model it better in a different way. I was thinking of using a nested family for the wire panels. I could control the angles better this way.
              -Alex Cunningham
