split segment on interior elevation view callout?
    Good day revit users, I have 1 question. How to split the segment on interior elevation view? anyone please. Tks.
    Just make sure you are hovering over the edge of the element you want to split not the face.
    hth
    Juan Carlos Moreno
    Sisley Cosmetics
      Are you trying to split the elevation view?? If so, select the crop boundary and then click one of the break marks (see attached image - yellow highlight).
        I think that the OP is going after like section lines that can be split to cause jogs. Elevations are not capable of doing that.
          Maybe this is what you are after. This is my workaround from an earlier thread, post #5
          Mark Balsom
            Thank you Autodesk (Revit 2014 new release) for enabling split segment feature on elevation tag family. Awesome!
