Roof cut
    Roof cut
    Is it possible to cut a section from a roof as shown in the image? I want to omit the red section.
    Thanks
    yes, model and in-place family void, roof category, and then use cut geometry to cut the void from the roof.
    Scott D Davis
    Sr. AEC Technical Specialist
    Autodesk, Inc.
    http://bit.ly/aboutsdd
      Thanks Scott, works perfect.
      Procedure for those who are unaware...
      Home/Component [dropdown]/Model In-Place
      Family and Parameters/Family Category - select roofs or whichever type requires a cut
      Provide a name for the void
      Select Extrusion or alternative from Forms
      Draw profile for the extrusion and provide Depth value
      Properties for the extrusion, Identity Data select Void
      Use Cut Geometry tool to cut the void
        You could use Vertical Opening on Home Tab. Same result and a lot quicker
        Mark Balsom
          Looking at the OP image, I´d say that it could even be achieved by setting the "Rafter Cut" and "Facia Depth" of the Roof to the right values...
            Good point! I forgot about that tool...
            Scott D Davis
            Autodesk, Inc.
