Looking for ideas on creating roofing that is easy for the whole team to work on. It's flat structure with tapered insulation. If I was doing the roofing for the whole project, I would just use an insulation material with a variable thickness, calculate the points I need, and enter it in. That would leave the miscelaneous lines I would need to hide with the linework tool. Is that really the easiest method to do it accurately?
See the attached pictures for the results of just modifying the points, and the desired end result after using the linework tool.
