Problem with Attach wall to roof
    I created a roof by using Model-in-place : Swept blend.
    There was something wrong when I attached the walls to the roof.
    Someone can explain and resolve it ? Thanks.
    detach....bring the wall top to below lowest point in roof and try again...
      No change of result...
        Can you upload this file, so we can troubleshoot?
          Your wall could be attached to another object, maybe a hidden object or to an object in another design option. Unjoin it first and then try joining it to the current roof.
            Here is my file...
            Swept Blend Roof
              Originally posted by nguyenkien View Post
              Here is my file...
              Swept Blend Roof
              You need to edit the vertices of the swept blend, then reattach the walls.
