Greetings, esteemed colleagues. I would like to know if there is a way to put windows into a turret wall. I've figured out how to cut vertical openings in said wall, but I don't know how to turn those openings into windows. Is there a way to do that? If not, what would be a believable workaround? Thanks.
Jenn, Not sure what you mean by a "turret wall", but if it´s a curved turret wall, and you need a curved window to put in it, then you should have a look at this thread
Hmm, I'm thinking something isn't quite right in your workflow. You can't change an Opening Cut into a Window. Rather, when placing a (correct) window, it will cut the wall automatically. If this is not happening, you might want to post the project and/or family so we can have a look.
I have curved walls based on arcs and windows are giving me a couple of issues where they placed on the curved walls (see attached). How can I make the...
I created a curved wall. Then I made an opening in the all. So far easy, Right? will when I try to adjust the wall open in either plan or elevation view...
When demolishing a window or door by default the opening where the door or window was fills with wall. Is there a way to stop...
July 30, 2012, 01:54 PM
We process personal data about users of our site, through the use of cookies and other technologies, to deliver our services, personalize advertising, and to analyze site activity. We may share certain information about our users with our advertising and analytics partners. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
