Zoom selected object
    Hello!
    Is there feature that allows you to zoom selected object?
    Originally posted by mona.miller View Post
    Hello!
    There are several addins around, here are a few free ones
      Thanks. But, is it possible that there is no command for this in Revit?
        yep, that is possible. Go to View/User Interface/Keyboard Shortcuts and search for Zoom to see what is available OOTB in Revit. I've been using Revit for 6 years and have never had the need for Zoom to Object. Don't you use a wheel mouse?? Point at an object and roll the wheel = Zoom to Object
          I want to select object in one view, and be able to go to another view and find it! Sounds to you logically?
            yes, that is my problem as well!
              sure, select an object in one view to highlight it, go to the other view and as long as it is in that view it is still highlighted, point your cursor at it and roll the wheel = Zoom to Object in Another View
                Select object, click corner of viewcube.
                  good tip for 3D views
