Spot Elevation show minus at zero.
    Why my Spot Elevation show minus at zero? How can I remove it?
    Would guess that the spot elevation is actually placed on a object which is a fraction from 0.000 eg. -0.000,4 ?
    At least mine does not show minus when placed on 0.000
      I checked it. spot elevation is placed on level which is located exactly at zero.
        Sorry for insisting. It must be something like this. There may be different reasons but the spot must be at fraction below zero. I don't see another answer.
        [email protected]
        http://4revit.com
          Unless the - (minus) have been manually added as a Prefix, I don´t see any other explanation either...
            I attached a project, you can see for yourself. Maybe I'm missing something.
              hmm, I don't see anything spezial. I used RAC2012. Maybe the version or PC configuration??
              [email protected]
              http://4revit.com
                Looks fine here. Opens with + 0.00 .
                Tuned off "Show+" in unit format and shows no negatives.
                Mark Balsom
                  Odd... Shows the - (minus) here, regardless of the "Show +" setting (RAC 2011) but only when annotating the level at 0.000 and not when annotating the Floor at the same level
                  You can move the level up by 0,0000001 mm to "fix" it... but that´s not really a fix...
                    I've been working on RST2010 (20090917_1515(x64)).
                    Spot elevation is placed on level - shows minus, spot elevation is placed on slab - don't.
                    Tuned off "Show+" - nothing has changed.
                    Сhecked on same computer with RAC 2011 and on another computer with RAC 2010 SP2 - the same thing.
                    When I create project without template everything is fine. So I think it depends on the template, but from what exactly.
                    Sorry for my English.
