Rotate Callout View
    Rotate Callout View
    Is there any way to rotate my callout view, with rotating the model or the callout itself?
    Basically, I have a callout around my pit openings. They are going north south, but, on my callout view, I put them east west because they are long and they fit on the sheet better that way.
    OR, do I leave the view as is and annotate it, then rotate the view in the sheet instead?
    Dan
    Edit: Should have read the entire post... You can also rotate the Callout View it self. Select the Crop Region on the Callout View, and use the rotate tool.
    Munkholm
    Administrator
      Now all I want is the ability to make non rectangular callouts.
      -Alex Cunningham
        Yep--ditto that.
        ...and on a related subject, a somewhat overlooked or unknown thing about sections is that you can rotate them as well to create "Plan Views"--place a section mark vertically, then rotate, and voila--a new "plan view"--good way to generate special views where you don't need or want a Level or Plan Region.............however, use with discretion.
        Cliff B. Collins
        Registered Architect
        Autodesk Expert Elite
          Well I'm stupid. I did that and noticed the callout itself rotated on the plan, so I undid it. I didn't even think to resize the callout after I rotated it. :laugh:
          Dan
