Problem with Topo surface
    Greetings!
    Im having a little issue with the toposurface and building pad, i must be doing something wrong because building pad seems to be flying in the air!
    i created the toposurface from a rectangel i imported from autocad, then i used the building pad to elevate the ground but the building pad seems to be floating?
    what am i doing wrong?
    Welcome to the forum, Ekkan.
    A building pad is supposed to have an effect over a toposurface, but where is the toposurface in your image? I don't see it.
      Maybe the problem the way how i created the topo surface. i need a flat surface so i imported a rectangle from caddie and made the toposurface, but i needed a half level up so when i created the building pad i created it in that level but it appears as if it was flyings :S
        I still don't see a building on a toposurface. In the first image, I don't see the toposurface at all. In the second image I see a rectangle in front of the building, not below the building.
          i just copied the toposurface that is below the building with out building pad, it doesnt looks right does it?
            I also don't see any toposurface at all. Or is it the rectangle before the building? But where is the building pad?
            [email protected]
            http://4revit.com
              You have no toposurface, and you built building pad. Your square is building pad which does not do anything. Create one more time toposurface and try again! and again!
