Door to Door Transfer parameter
    I understand that within revit itself we can create a schedule that has the function of telling us which room that the door is in (Door to Door) this can be exported to excel/xml/etc.
    However if you create an ifc model you cannot find the door in the space i.e the data does not travel with the door as a parameter that can be searched for or extracted.
    Is there a way of adding the a parameter to the door that automatically takes the door to or room from data and adds it to the door itself and not field of available options that the schedule refers too?
    Thank you
