Wall end wraps
    Wall end wraps
    So I would like my brick layer to wrap at the ends, which is easy to do however I only want it to wrap 4 inches, roughly the thickness of an actual wall layer. I've achieved this, partially, at the inserts by adjusting the window family but I can't achieve it at the ends. It's just all brick wrap or all interior material wrap. I'm really only interested in it working in 3d but I have a hunch that its not possible. Any ideas?
    You could model another wall with only a brick layer, then join the two. If you want the brick to be flush with the stud (instead of offset like I have it), then you'll probably need to use a void on the main wall first, then put in the small wall. Although, I haven't tested that out.
    You could possibly create a family with just an opening and a RP with a wall closure. But then you'd have part of a family "sticking out" past the end of the wall. Why do you need this exactly?
    Dan
      parts perhaps?
      Cameron Palm
      Project & BIM Manager
      The Preston Partnership
