analytical model error
    Not sure how to fix this model issue i can not get the analytical model to show unhid the analytical model on the bottom left icon all the VG items are checked to visiable but still see no analytical model
    select the offending object, then look in it's properties. There's a check box for structural, and enable analytical model. You have to have structural checked to be able to enable the analytical model.
    Dan
      i made a family object instead of the walls and slab object i was trying to make where i work we refer to them as plenums
      even when i worked at a structural firm i dont recall getting that error.
      i take a look at that thanks for the ansewer (i didnt get an email that u had responded)
