Revit vs Suite
    Revit vs Suite
    Is there a way to tell if what I have installed is Revit through a suite or just Revit? A while back the splash screen was different, but they don't seem to be any more...
    Hit the drop down next to the Q mark on the top right.
    Go to about.
    Hit the Product License info and check you Package version top right
    Cheers
    MW
      Go the the Big Purple R (aka Application Menu) and pick Licensing, then pick Licensing Information.
      The License Name should give you a clue.
      Here's mine:
      Last edited by DaveP; May 26, 2011, 04:49 PM. Reason: Guess the bunny types faster than I do!
      Dave Plumb
      BWBR Architects; St Paul, MN
        Glad to have your license information now. Thanks.
        -Alex Cunningham
          Copied, and sold already, haha ;D
          Joke
            Here's mine:
            I belive the licensing information only shows you what license you have checked out. If I install Revit Suite on all my machines they will pull Revit license before they pull Revit Suite license.
