Insulation and Lining Updated?
    Hi all,
    I have a new notice that I have never seen before and I am wondering what it is about. It poped up while I was opening a 2010 file in 2012.
    "Insulation and lining for fittings have been updated. In some cases, this may cause the thickness and the line graphics of the insulation or lining to be incorrect. You should check the values for the thickness to be sure they have updated correctly."
    What is that about?
    Thanks, Sarah
    Sarah Foulkes
    Not a Revit Robot
    I'm fairly certain this deals with Mechanical and Piping insulation in MEP. Are you opening a file with Duct/Piping work from MEP?
    • Plumbing Piping Insulation
      Is there a way to add insulation to plumbing piping in Revit 2013? All instances for adding insulation are grayed out? Any suggestions?
      October 22, 2013, 03:49 PM
    • Automatic placing insulation
      The last couple of days have i been placing insulation on ducts and pipes. It was a not the best time of my life. I then thought to myself if it was possible...
      January 11, 2017, 02:45 PM
    • Can not delete insulation off pipework
      Hi
      i have taken over a job which has all the pipework with insulation on, I need to work and make changes, I have removed the insulation, but it...
      March 12, 2019, 04:39 PM
    • Pipe Insulation for Tees - Garbage!
      Alright, the title of this thread is just my frustration over Revit's insulation for tees.
      They look like big triangles. Has anyone overcome...
      June 13, 2015, 05:59 PM
    • Insulation
      If you use the insulation tool in Revit MEP 2012, then the insulation is over the whole length of the selected pipe. Is there an way that the insulation...
      August 23, 2011, 01:52 PM
