coverage acroterion - parapet
    I looking for a method to finish a parapet on moderns houses.
    In french, we say "couverture d'acrotère", could you help me ?
    Thanks
    Il vaut mieux un qui sait plutôt que dix qui cherchent
    I'm Just simple Architect en France !
    Is there any particular reference that you could post to clarify a little?
    Juan Carlos Moreno
    Sisley Cosmetics
      I would like to make similar of join picture
        What part of the building are you refering too? Could you maybe hilight it? Google translate won't give me any usable translations for "couverture d'acrotère"
          Its the parapet cap I believe. Google the term and chose images. without translating
          You can change edit your wall type> edit structure> add a sweep to your wall> Load a profile that has the parapet cap that you want to use, set its location etc.
          I don't have revit in front of me at the time to double check
          Juan Carlos Moreno
          Sisley Cosmetics
            I cannot understand how people can fold pages of of books this way.
            I Think the answer would be here very soon if this was a French forum. If I understood right it would be something like - Just place walls, floor, roof just like in real life - I think it's about attika floor on top of the building?
            [email protected]
            http://4revit.com
              I beleive a wall sweep is what pcamilti wants.
              If so, pcmamilti, get into profiles!
              Gonçalo Feio
                Hi all, French and English speaking users!
                you're right Juan, pcamliti asked about how to add a parapet cap. So your answer is cool.
                it could be also IMHO a wall sweep defined outside the wall type, in fact with the wall sweep tool. maybe it's easier this way to control the ends... my 2cts.
                A brief snapshot here from the French section (hope you don't mind):
                "pcamliti, la solution se trouve dans les profils en relief. il faut que tu charges dans ton projet un profil correspondant à ta couvertine, et tu ajoutes ensuite ce profil avec l'outil Profil en relief. Tu peux aussi comme le suggère Juan modifier la structure de ton type de mur et ajouter de la même façon un profil en relief, à placer au bon endroit. à toi de voir."
                :thumbsup:
                Julien
                P. DAC
                  Hi and thanks, for all reactions. More thanks for Julien translation
                    Parapet and isolation
                    Bonjour,
                    anyone know how to place insulation under parapet.
                    Thank you very much, detail on picture
                    Alfred _ Architect - Paris
                    • Wall Join Macro
                      I'd like to get a macro / addin of some sort that will allow me to select a join condition (miter) and apply it to walls as I pick, similar to how the...
                      July 25, 2013, 03:09 PM
                    • Polycurve to curve
                      Hi guys,
                      I made a polycurve from a rectangle, but it could be anyshape.. in order to offset equally each side..
                      However, in order to...
                      January 28, 2021, 09:12 PM
                    • Complicated Roofs
                      Hi Guys, I am newbie to this forum and would love you can assist me little bit with this roof. How can i make it i have trying a...
                      October 4, 2017, 06:13 AM
                    • Can a Experienced Revit user Screen Share
                      I really would appreciate some 1 on 1 help for an hour (longer if you can).
                      I setup the session using http://www.uvnc.com/.
                      May 15, 2011, 02:27 AM
                    • Please Help Me!!!
                      When you think of us good folks in down under in New Zealand, what do you associate us with in your minds. You will notice there is missing an obvious...
                      The Furry Bird with a Long Beak (the Kiwi)
                      43.75%
                      7
                      The furry Fruit that looks like a Kiwi but comes from China
                      0.00%
                      0
                      Clean Green Nation
                      25.00%
                      4
                      Our World Champion Rugby Team
                      31.25%
                      5
                      March 28, 2012, 06:28 AM
