Room bounding offset or smth?
    I tried to split the wall which is separating room bounding, i want to count that area as usable area but dont know how... Pictures will u show u idea i guess
    Sounds like your computation height is above the opening in the wall... You can change the computation height on the properties for the level type (see attached)
      Still does not work.. Tried almost many computation height, nothing changes in plan.
        Should work... at least it did in my test - Could you upload the project to Dropbox or somewhere similar, so we can have a look?
          Could you please give me tips , what is the best way to "cut" building and to paste into another project in order to show to you?
            Anyway, here is my whole project http://www.speedyshare.com/files/286...may_monday.rvt
            plan view 0-parter
            If necessary here is download key kuzimomexato
            Ah and damn i accidently activated workset, so i doubt that u can change smth... RAC2011 im using..
