Curtain Wall inserts into walls as windows - finish returns
    This is probably a hopeless question but if you don't ask etc. ...
    On the occasions I use Curtain Walls as windows inserted into external walls the wall finishes never return into the opening reveals as they can do with family inserts such as windows and doors.
    Is there any way to enable this ability for Curtain Walls used in this way would anyone know?
    William Sutherland rias riba
    WS Architecture Ltd
    Nope, not possible...
    There has been a similar thread recently, but I can't seem to find it.
    EDIT: here it is
      Nope, no way to do this - Besides creating and inserting a "empty window family" to create the opening and the returns before you insert the CW.
        Oops, must have missed that.
        Thanks anyway - and on a Sunday too...
        WS Architecture Ltd
          Well, now you know how we get our post count...
            I don't work at all with walls other than curtain walls but isn't there a way to create an opening in a wall and have all of your wraps as you want them creating a hole in the wall for a window? IOW don't use the curtain wall to create the opening? If you can do that just create your window out of curtain wall separately without using the Automatically Embed option and just put the window in the opening...just a thought
              Dave is correct. Don't use the curtain walls to create the wall opening. Instead use a wall opening or opening family to create the opening and make the finishes return. Curtain walls don't have a host technically so having the opening already there isn't going to affect the curtain wall.
              Of course, the completely obliterates the reasons you'd use curtain walls as a window, and would mean updating 2 objects every time you need to move or resize said "window." I would suggest reviewing your curtain walls that you've used in the past. I would guess that they are fairly simple and/or similar mullion patterns and could easily be created into a "generic" window family that you can start from for a project. This would give you the curtain wall look, with the window behavior.
                And besides the extra use of words, how does this differ from the reply I gave?
                Originally posted by revittotd View Post
                ....Of course, the completely obliterates the reasons you'd use curtain walls as a window, and would mean updating 2 objects every time you need to move or resize said "window." I would suggest reviewing your curtain walls that you've used in the past. I would guess that they are fairly simple and/or similar mullion patterns and could easily be created into a "generic" window family that you can start from for a project. This would give you the curtain wall look, with the window behavior.
                Depending on the situation, I may have to strongly disagree. In situations where architects is using Revit as a DESIGN tool, CW's are much more intuitive to use, and they won't need to think about changing the values in half a million different parameters, to get the DESIGN they want.
                And even though it means manually swapping of the CW´s to Windows later on, I´m a big fan of letting the Designers use CW's, and not restraining them from being creative with the window design, and mullion placements. And if the earlier mentioned "window family" is purely instance based, it can simply be placed and locked to the CW borders, and thus update automatically along with it - That said, in most cases were CW's are needed for windows for design reasons, we don't really need the returns to be shown :beer:
                But having a built in parameter for interior and exterior returns with CW's would be a great feature though.
                  Many thanks for the thoughtful replies. :beer:
                  Curtain walls used as inserts are extremely useful and an example of how we adapt the tools provided by the programmers to our particular real World needs.
                  (I can't be the only user who has never touched the conceptual modelling bits of Revit?)
                  WS Architecture Ltd
                    No you're not. I have never even taken a peek. Would like to, but never enough time, and haven't had a use for them yet.
