Leader attached to callout head
    I have created a custom callout head, and loaded it into my project. Works all ok apart from the following.
    The leader that is attached from the actual callout to the head obviously moves with the head when dragged around. I have used an oval type shape as we have quite long dwg names. The leader quite clearly operates around the callout head, on the basis of a circle... (see the two attached images)
    Can I somehow amend where the leader terminates against the callout head, or should I stick to using circular heads..!
    cheers
    I learned long ago, never to wrestle with a pig. You get dirty, and besides, the pig likes it
    Long dwg names ??
    Anyway, you´re right - Revit expects a circle to snap too - but if you use the "elbow" in the leader, you should be able to get the leader aligned to the center of the half circles in your "oval" - See the attached.
      Cheers Munkolm..
      Well.. When I say long dwg names.. we just end up with a huge circle that we dont like.. You know what Architects are like.. ;-)
      Will elbow my way throu it....
