CMU Model Hatch
    CMU Model Hatch
    It has been a while since I did CMU coursing, but for a project I am working on we have 390x190x190 CMU (400x200 with mortar). How do I get a model hatch to do this?
    is the CMU really 15.748x7.87402x7.87402???
    -Alex Cunningham
      This is what is specified in the GOST specifications for the project.
        well you will need to make a new pattern file with the correct pattern sizing.... hatch22 works well.
        -Alex Cunningham
          Originally posted by Alex Cunningham View Post
          hatch22 works well.
          No longer free mind. Jus' sayin' - Gregory was right to make it so.
            This might help. http://www.revitforum.org/architectu...-pat-file.html IDK though if 400x200 is a standard masonry unit size... but the metric pat file might have it already.
            -Alex Cunningham
              Are you talking about Elevations, or Wall Sections?
              Since you said "model hatch", I presume you mean Exterior Elevations.
              Go find your Revit.pat file (the metric one might have a slightly different name) and find another CMU pattern that's close. Or at least the same type of coursing.
              Then modify the distances to get your 400x200 (I wouldn't worry about the mortar unless you need to show it in a detail at a finer scale.)
              Might take a few tries, but a standard running bond pattern isn't too bad to figure out. The instructions are at the top of the .pat file.
              Or buy Hatch-22:
              Last edited by DaveP; January 21, 2014, 05:39 PM. Reason: Damn it, Alex! I wish I could type faster.
              Dave Plumb
              BWBR Architects; St Paul, MN
                Got it!!! Used Notepad++ and a few tutorials on how the text needed to be! Thanks for the help!
                  Also, just found the .pat revit files which had this in it! Very cool.
                  Thanks again!
                    Just use the "simple brick" or "brick pattern with grout" tab of the attached spreadsheet and plug in your numbers.
