Filled region visibility
    Hello guys, boys and gentleman. Today i am wondering and i would like to change visibility of filled regions compared zoomed in or zoomed out, in pictures u will see what i mean. Hardly visible is zoomed out. How to change it visible so it would be as surface patterns in or out zoomed? RAC2011
    Make it part of the floor slab instead (Slab Edge with offset)
      Or possiably use a model hatch.
      -Alex Cunningham
        Most of the patterns are drafting, model patterns only few, how to copy all from draft to model? should i import 1 by 1?
          Also check the drafting pattern orientation. I've found that some of the orientation settings cause it to greyscale like this and others keep it bold. I can't remember which works best for which situations but I'd suggest playing around with that. (ie: Keep Readable, Orient to View, Orient to Object)
            I wish, one part of slab edge joined floor, another "Can't cut joined element." so im using regions in section..
              You don´t need to cut anything.... create the profile for the "Slab Edge" that you need, place it, center it, and make sure that the Slab and Slab Edge material is the same...
              See the attached :beer:
                Yeah, left slab edge joined without problem, right one doesnt..
