Stair Railings
    Stair Railings
    Is there any way of achiving this type of railing for a stair (see images below)? As you can see, the railing stop at the landing (last thread) of the stair & loop back to the middle rail... Any suggestion?
    Definitely. A custom Post will get you anything actually. For stopping it you just need to edit the sketch
      What do you mean by "editing the sketch"?
        Select the railing and then click the 'edit' button that appears in your modify tab.
        @ Daniel, I'd love to see the custom post that does what's pictured. Do you have one?
          Just created one for you Elton, 15-20 mins
            Nice! Do you need to know the stair angle to create this post or does it adjust automatically?
              [ATTACH=CONFIG]15180[/ATTACH]
              Can you get it to join cleanly around the 180 turn at the mid level landing? I can get it done with an AC but I've never seemed to be able to figure it out using a regular railing.
                That sketch comes from AutoCAD... BTW I cannot get anything done... The way i see this is that each stair have a different slope so building an end post for each angle & editing the railling family type seems to be time consuming... Plus i am a newbe on revit & i've never really sketch a railling before... Thanks for helping...
                  Indeed, the colours give it away
                  Although most of what you'll ever need can be created natively, creating custom railings is very time consuming and confusing compared to other areas of Revit. IMHO the railing tool still needs a lot of development. There is a great video by Julien Benoit where he creates an adaptive component as a railing for stairs (or anywhere else).
                    Thank you very much Elton! This forum is great!
