3D view from above
    3D view from above
    Hi. I have seen that this kind of view is possible in Revit but I cant seem to be able to achieve it.
    Direct from above but in angled in a way that you can see all walls to show depth.
    Totally Possible. You need to place a Camera view, looking straight down (or as close as you can get it).
      [ATTACH=CONFIG]15124[/ATTACH]
      3D Isometric "Plan"
      Open 3D View>(at the view cube hover over the hiding little down arrow)>Orient To View or Orient to Direction
      Orient To View with, say a plan view will respect the cut plane, etc.
      3D Perspective "Plan"
      Cut 2 section views that cross in the middle of the project or area in question>Create a camera view (pointing as straight down as possible (from high enough to capture the area in question) -the 2 sections are to triangulate the exact camera location
      In camera's watch orient to view as that can send your camera unnecessarily high ;-)
      -J
      http://about.me/JayZallan
      Tweet, Link or Blog me up!!!
        Quick method for single story.
        Place a camera view anywhare in plan view. Then in the "created perspective view" hit "top" on the view cube, hide roof, done.
        Edit
        or Jay's way to focus on a cut plane or level
        Mark Balsom
          Marvelous folks. Many thanks!
