Modifying floor layers
    Is it possible to move floor layers manually like i can do with walls?
    No for floors it can't possible.
    Can U breif about your requirement?
    Yogesh
      You can select the layer and click the up and down buttons. That's about it.
        Martijn...
        I think he is talking about a layer modifications which can be done in a section of a wall.
        Yogesh
          Yes and no
          You cannot Unlock layers of floors like you can walls (see attached)
          You can however use the 'Join Geometry' tool to join floors and walls which will order the intersection based on the 'function' set in the 'Wall Type' dialogue. (see attached)
          I used to be high on life, until I realised it was cut with Morons.
          Combating ignorance daily through learning.
            Tell me more how you do it, concrete wall just goes on whole floor, not on the concrete slab..
              Bangobeat, there are at leat 2 options:
              1) A true 3D solution : make the finish floor a separate floor entity, and adjust the sketch in plan view as necessary.
              2) A 2D solution: use View > Edit Cut Profile, to "fix" your section view, modifying the boundaries of the floor finish layer.
                Sorry, I was mislead earlier...
                THe trick here is setting the right priorities to Wall and Floor layers. Basic groundrules:
                - The primary rule in deciding which layer cuts which is the Function (structur > substrate > etc..). The higher in ranking order always cuts the lower when joined.
                - Layers inside the Core Boundary always cut layers outside the CB with the same "strength"
                It seems to me you need to review the assignment of Function and placement in relation to the Core Boundary for both Wall and Floor to make this work.
                  To Clarify,
                  There are 6 'Function Types' from "1 Structure" to "Finish 2".
                  These determine the joint 'hierarchy' and how the join is created.
                  To activate the join, use the "join Geometry" tool. Alternately click 'yes' when completing your floor and prompted "would you like to join geometry and cut the overlapping volume out of the wall(s)?"
