Is there a way to quickly align two objects so that they become parallel to each other?
Let's say that I have two walls 10' apart from each other. One wall is slightly non-parallel to the other. So I want to make the two walls parallel to each other while maintaining the distance between them.
If you use the align tool, then the wall out of alignment will just move and overlap the other wall that was used to define the alignment. So it's sort of like align with offset.
I don't want to recreate the wall, and I don't want to have multiple steps like creating an offset reference plane and then aligning the out of alignment wall to the the new reference plane. I might have a wall on opposite sides of a building that were not drawn aligned and I want to click a wall on the east side and make a wall on the west side parallel to it.
Anybody know of a way to do this?
