Material Tag for Faucet don't work, why?
    Hi all I need your help to solve this: I'm tagging by material several objects in my model, but when I try to tag the family Faucet-Bradley_Corp-Aerada_1200_Series_CS, which I attached in this thread, I'm not able to do that, why?, those are the steps I've follow
    1. I'm using the same material tag for all my objects, so the tag works properly.
    2. I assigned a material to all the elements I want to tag by material.
    3. I checked out if the family has a material and yes it is.
    so, if you have any Idea please comment, best regards.
    E.A Poe
    I took a quick look at the family, the reason it won't tag is because the forms which have a material applied are only visible in 3-d. The detail components that are seen in section can't have a material, and thus won't tag in other views. If the family needs to be tagged the modeled components need to be visible in the appropriate views.
    Julie Kidder
    Architect + BIM Director
      Just another subtle example why the "tow the line" mantra of no 3D elements visible in plan views is often nutty advice.
        Hi JMK, tnx a lot I don't see those detail components until you mention it, jejejeje, I just seek for the reason that the material tag doesn't work, that explains all, best regards.
        E.A Poe
          xAThousand. Freaking hate that stuff.
