Course detail level - Remove surface textures
    Does anybody know if there is a way of setting the course detail level to remove surface textures? I am specifically interested in removing the surface patterns on the floors whist working on models as the snaps are effected by the surface patterns.
    Filters are a good tool for this task. This would not be limited to course view (v medium/fine) though, but will do what you need.
      Thanks for the input, I must say that I have not really ever used the filters - Might be a good time to start!
        Visability Graphics / Floor / Patterns / Override, uncheck visable, done.
        Better still make yourself a "view template" with this override already applied, then just apply view template.
        or
        select a floor / right click / override graphics in view / by catagory (for all floors) or by element (for just the floor you selected) / surface patterns and uncheck visable
        Mark Balsom
          Yes, of course! VG/Floor/Pattern/Override.......*much* better way to go. That'll teach me not to respond right before going to bed. Wasn't thinking clearly enough.
          But i have used filters effectively in the past to turn off surface patts globally for all types of objects. I use it as an on/off toggle of sorts. But now with the new temporary view template override, that would work just as well.
