Call-Outs: Elevation Visibility - not possible?
    Hello All,
    I'm trying to show a detail elevation on a detail plan that was created with a call-out. I vaguely remember this was an issue, and I can't remember how we fixed this. Does anyone know if there's a way around getting elevations to show on call-outs?
    Thanks,
    as far as I know, you have to redo the callout and make it a floor plan, not a detail view. Select it in the type properties when you first start the command, before you draw the callout boundary.
    Dan
      D: oh wells. thanks!
        Yeah, elevations exist in floor plans only. Some at my office have attempted to suggest using dummy callouts to get around this, but I refuse. It's too common to shift sheets around towards the end of CDs and then you'll have a bunch of callouts that are wrong and nobody checking them (since Revit is always right, right?)
          Yea, I agree on the "dummy call outs". We used those before, and it definitely created more headache down the line as we reorganized sheets etc.
