Insert a Linked Revit File
    I linked my porte-co into my house file, but now I want it to be part of the file, not linked. What's the best way to do this? Is there an easy button?
    I tried to paste it in, but I'm getting some constraint errors.
    Dan
    Select it and hit the Bind button in the option bar.
      Cool, that's what I thought. That will make it so it's like I drew it in the project, right? It won't be a group or anything? Or can I just ungroup it (if it is)?
      Ah, I'm scared to do it! :laugh: I don't want to mess up the project. It's giving me the "unlinking cannot be undone" message.
      I thought I was being smart by linking it. Maybe not.
      Dan
        Itll make it a group; if you ungroup it, its just like you made it in the project. No worries, its not that big of a deal. You can always regroup it, and then convert the group to a link as well.
          HEY! don't be messing with my Easy Button!
            hey Aaron, once you ungroup the former link I'm assuming that there is no way to have some sort of "selection set" to make the regroup a simple matter. It would seem that for a complex bunch of link geometry that it would be tough to get it all back together ?? Maybe make a copy of the group and ungroup the copy ? It always scares me going down a path that I can't see the end of...
              Why would you need to regroup it, since the file that was once linked is still a file. You could just relink it, right?
              There should be an easy button. :laugh:
              Dan
                makes sense I guess. To me if you put a steak in the meat grinder it doesn't ever want to be a steak again. But I guess Revit is smart enough to make a group from the link rather than covert the link to a group. I haven't had any reason to do this but I'm going to try it out just for my own education.
                As I said on the other side of the fence, I'm working on the Easy Button Family. If only I could figure out what family template to use
                  I never thought of that. Surly Revit wouldn't do anything to the linked file. Buy ya never now. :laugh:
                  Dan
                    I wouldnt ungroup it, personally. If i thought (once upon a time) that it should have been a link, i probably still want it segregated in some fashion.
                    Converting a group to a link isnt flawless anyway. It does it in to a blank file, and not in anything resembling an office template, which really sucks with things like Phase Filters, and Object Styles.
