Dimensioning wall faces - fail
    Problem 16
    I am always wondering how to dimension wall some of the faces?
    in my case basement wall - 250mm concrete, 100 insulation. dimension cant fix into layer where is insulation.. and i do mark the where is dimension bar "wall faces" and i tried all of them..help.
    Have you tried activating in the options bar the "prefer wall faces" instead of centerlines? Or have you tried pressing the "tab" key to cycle through the available edges?
    Juan Carlos Moreno
    Sisley Cosmetics
      The tab key.. For the win. You live and you learn, Thanks JCM.
        No problem, glad I could help
        Juan Carlos Moreno
        Sisley Cosmetics
          One thing I learned early in Revit. The tab key does a lot of things. When in doubt, hit the tab key.
          That, and look at the status bar at the bottom left of the screen. It sometimes tells you what Revit is expecting from you. It's useful when things aren't doing what you expect them to. Especially if you're new to the program.
          Dan
