Adding Multiple Balusters In Railing
    Nothing I'm trying works. I'm sure there's an easy solution.
    I created a railing to use as a fence. It has 2X12 railings top and bottom, with 2X12 "posts" on the sides. The intermediate balusters and rails are 1/2" x 1/2", creating a 6"x6" grid. So far, so good.
    I also need to add a 4x12 baluster every 10' max along the fence line. I can't get it to work. What's worse is that's just a max dimension. If the fence line is only 16', then it will split it in half at 8'. It just can't go over 10' spacing. I've shown them in blue.
    How do I do that in a railing?
    Dan
    I would use a 2 x 4 in the design instead of a 4 x 12 Unless there is a structural reason to do so
    In terms of how to do that sorry but I'm still a noob in the realm of Railings and most things revit haha
    Look forward to the answer by one of the Revit Masters
    Juan Carlos Moreno
    Sisley Cosmetics
      Well, you aren't the one signing the checks! :laugh:
      Actually, what it is is a (2) 2x12's sandwiching the wire fence part (the 6x6 grid). That's what holds it all together. Around 5000 acres. This fence will cost more than my house! :laugh:
      Dan
        Just make a module and copy it throughout
        it's not like the property is big
        Juan Carlos Moreno
        Sisley Cosmetics
          Thankfully I'm only showing the entry gate. The rest they can make up in the field. Literally. :laugh:
          Dan
            Is this what you mean.
            I think the images will tell you more than me explaining.
            edit
            select the baluster in baluster placement properties and Duplicate..
            Mark Balsom
              Nope. That's the result I'm getting. I need the 6x6 grid still, along with the 4X12 every 10'.
              Dan
                Just add the ballusters that are missing (you will have a LOT!) and offset them the distance that you need
                Just imagine the 2 x 12 framing this thing
                JCM
                Spanish Moderator
                Juan Carlos Moreno
                Sisley Cosmetics
                  Think a way to do this is create a family profile, (for the mesh). Insert into railings. Give the profile a hatch to represent the wire, set transparency to 100%. Should work I will try and post file later if still having trouble.
                  Paul
                    So the 4x12 could end up anywhere within the grid, mid panel, third panel, anywhere....?
                    Mark Balsom
