Surface pattern missing in 2D
    I need to create an 8'x8' grid pattern on my sidewalk areas. It shows up in 3D but not 2D. Same problem with any patterns on the floors too. Any idea what may be the problem?
    Thanks
    Welcome to RFo. :thumbsup:
    Surface patterns turned off in VG?
    Surface patterns filtered out in VG?
    Surface patterns turned off by element in the view?
    View Range Settings?
    Dan
      Are you using a bump on your material or are you using a surface pattern?
      -Alex Cunningham
