Making sure all views and details are on sheets
This topic is closed.
    This is a noob question if I've ever heard one, but here it goes:
    I'm at the end of a small project, so it's not a big problem now. But, on bigger projects, how can you be sure that all of your views, details, callout, section, etc. etc. make it on to a sheet? I can see issuing a set, then realizing there is a view missing.
    Any ideas? Or is it just a matter of checking and rechecking to make sure you have everything?
    Dan
    to the best of your ability manual checking is the best. Quality Checks is what we call them.
    This is also a way Revit can help in crunch time though. Browser Organization (see attached image) F1 has a lot of info on this.
    -Alex Cunningham
      got it. I'll check it out in the help files. Thanks.
      Dan
        You could create a View List Schedule and schedule the Family, View Name, Sheet, and Sheet Name fields. It won't show legends or schedules though.
          View tab/Sheet Composition/View. If your view is in the list it's not on a sheet. I don't have Revit open right now but I think you need to be in a sheet to make this work.
            I like this I am going to add this into our template. Awesome for detailing! My soultion simply moves the view under the sheet in the browser.
            -Alex Cunningham
              That's not accurate, for some reason. You do have to be in a sheet, so I opened my sheet with my schedules on it. Every schedule showed up in the list! It's obviously on a sheet, I'm looking right at it!
              Dan
                Theres a much easier way.
                You can create a Project browser sort called "Views not on sheets," and Filter by Sheet Number (it wont exist). Then the ONLY views that are in the top of the project browser, are the views NOT YET placed on sheets. Everything else is only accessible down in the SHEETS portion.
                If theres anything in the top, its not on a sheet.
                  Yep, just found it. Works great. :beer:
                  Dan
                    well just shows to go ya that you get what you pay for. I use this method to check which view are not on sheet all the time. I never noticed that schedules didn't follow the rules. Probably because as soon as I create a schedule I put it on a sheet.
                    Sorry for the bogus info. In the future I'm going to go with Aaron's suggestion also
