Roombook Extensions for Revit
This topic is closed.
    Hey guy's just found this link on Revit OpEd
    http://bim-reviteer.blogspot.com/201...for-revit.html
    and am downloading right from now subscription center. Looks interesting.
    Maybe this should go under R&D /API ?
    Quick update
    Well worth a look guys, could be very handy.
    mark b
    Mark Balsom
    This thing is fantastic !! hit export and checkout the exel data generated. Will have to check on how accurate quanties are, but so far most impressed.
    Didn't know this was in the pipeline !!
    Mark Balsom
      Not a bad tool, I had a chance to give it a quick whirl on beta.
      It is useful as a tool more than key schedules and less than codebook/affinity/onuma for room data sheets.
      I was a bit disappointed in the furniture only elements which is surprising since the developers were working on healthcare projects at the time.
