How do you like to model pitched roofs when needing to cut sections through it? I started by doing a pitched roof with layers including the top truss chord, and then a flat roof with one layer for the bottom chord. I'm not a fan of it, though, because it somewhat implies that a truss is being cut through the long way. I don't want to see the bottom line of the top chord as thick as the other lines when cutting parallel to a truss, and I don't want to see it continuous when cutting perpendicular to a truss. I'm thinking of eliminating the chord layers and detailing that in, but I hate detailing elements if they can easily be represented in 3D. What method do you use? What are the pros and cons?
Pitched roof sections
Does anyone have a roof truss with the top cord that is adjustable. need for a 1/4"/12 roof with flat ceiling attached to bottom of truss. needs...
Channel: Structure - Family Creation
February 3, 2015, 12:04 AM -
I'm very green to Revit, I'm hoping this is an easy issue to resolve. I am using a Howe Flat Truss family for my prefabricated roof truss. I've added...
October 16, 2018, 09:12 PM -
Hi All
New at this game but I would like to ask the best way, if possible, (other than pen and paper) to do simple roof truss calculation...September 8, 2012, 01:25 PM -
In roof properties there use to be a choice between Truss or Rafter which determined at what point the roof pitched from, inside or outside of frame....August 9, 2011, 11:27 PM
Hello I am having a bit of a problem with a roof truss. The roof truss editor is simple, with its lines.
Only problem is when you add a timber profile...-
October 24, 2019, 04:00 PM -
Monumetric Footer In-screen
