Hi All,
There is a known issue with the Wacom Intuos 4 drawing tablet driver and Revit 2012 Architecture Suite for some configuations - mine unfortunately
When changing a material appearance in the materials dialog box, Revit will crash without any recovery file save.
As noted above, Autodesk are aware of the problem, (and are hopefully working around the clock to fix it!?!), but at the moment, the only options seem to be removing all traces of the Wacom driver and putting the tablet in the bottom drawer for a while or use a different computer - one without a tablet - to change material appearances.
Damn :banghead:
Damn :banghead:
