Elevation Tag kicking my a$$
    why do these two look different when they have the same properties?
    I want it to look like ElevA (normal)
    Have you tried removing the view name label from the family?
      I thought to try that but not sure which family to open. would it be Elevation tag or Callout Tag?
        I tried to edit the family Elevation Mark Circle_Body to make the ref to the view name invisible but I got this error msg.EMB_C.jpgError.jpg
          doh! I just needed to select Edit Type, then Elevation Tag (1/2" Circle) then the option w/o the view name.
          these things I do at the beginning of a project and forget how to do them by the time I start another.
            set them in your template
            chad
              I don't recall the edits I made, so here are the 2 families needed...There are Types embedded for both BLDG and INT. Elevations (Filled & Unfilled)... The only issue are the lines in the Interior (unfilled) ones...but if I can get over it, perhaps others can ;-)
              You can download from here:
              "Circle" 1) https://www.box.com/s/ehf4qslk8e1lvy2yn6a1
              "Pointer" 2) https://www.box.com/s/z5gb2prv9icaubydx2rl
              JBZ
              Senior Member
              -J
              http://about.me/JayZallan
              Tweet, Link or Blog me up!!!
